Any pros or cons to using stainless for axles? I have some extra 1" solid stainless that I used for a new drive shaft on a boat. Is it to hard, to soft, or just right? (Sounds like the three bears) Both of my front axles are now bent, slide into a tree in the snow.
Mike
Mike
I,m sure he would have an answer to this question .
The last 2 numbers of all these alloys are the carbon content & makes it easy to control the desired heat treat for whatever application. The benefit from using any one of these alloys (if heat treated correctly) is that they would have some spring in them. When I straighten a 300M axle after heat treat I sometimes have to push it an 1" in a press just to get it move .005. If I push a stock RI axle 1" in a press, it would stay bent 1". No spring or memory. The stainless would probably work, but it wouldn't be my choice for axles.
