tomahawk...no rev.right side..?
  • tomahawk...no rev.right side..?
    no reverse on the right side...were to start.....
    Start with the diamond on the t-20. They come out and pins are under north that shift the transmission. Make sure both sides are going fully forward and backwards when you are shifting. If they are, you need to either put it in forward and push down on the diamond to get the pin on track, or pull the diamond out and replace the pin. If they aren't going fully back on both sides, look for bent, broken, or disconnected linkage.
      ill try that first...thanks..?
        pulled diamond all looked good ,,gos good in forward wat next.....?????????? were to look for a tennison..sproket. martin 50bb17h..any ideas.....
