Need to do some repairs on my ABS floor and was thinking the HDPE goo and fiberglass. Will it stick ok? Whats the mixture ratio for acetone and material?
ABS Attex Floor
Goo is made with abs and acetone. If you have an abs floor pan, it will stick just fine. Make sure you clean the surface with acetone several times before hand. This will soften the pan and prepare the material to bond. There is no ratio, just keep throwing chunks in until its the consistency you want. Fiberglass cloth and abs goo requires a thinner mixture than what you would use if "bondoing" a spot with goo.Originally posted by Toys4Me View PostNeed to do some repairs on my ABS floor and was thinking the HDPE goo and fiberglass. Will it stick ok? Whats the mixture ratio for acetone and material?l like to buy stuff and no I don't do payments!
Originally posted by David3rd View Postwow they still call my ABS body repair stuff GOO!
Well a voice from the past, haven't seen since the first Copper Ridge.sigpic
