I am trying to remove the chassis out of my attex so I can presure wash the inside and repair the holes from the outside and inside. Is there an easy way to remove the axles without removing all the chains? Also where can i get new bearings , i have one that was leaking and has play in it
removing axles from an attex
.Originally posted by Bikerman883 View PostDo you happen to know the part number? I am in Chicago we don't have. Buffalo bearing but have a bearing headquarters that might have them
Get the bearings out and get the numbers off the old ones.
Be sure to get triple seal outer bearings.
Order them from Buffalo Bearing, they will be a cheaper price and a good bearing.
Lots of cheap bearings out there.The trouble with retirement is.... I never get a day off !!!!
Yes the axles go through the outer bearing&flange, then into the tube which has 1 or 2 sprockets on it.Originally posted by Bikerman883 View PostIt looked like the axles went into the tubes for he sprockets. That's why I was wondering if I could just pull then out to get the chassis out and leave the chains and sprockets
The tube is secured to the axle with a through bolt (usually 7/16") on our Attex's.
There as also usually locking collars on both bearings, these need to be loosed by 1st removing the set screw, then tapping the collar CCW or CW to loosen the collar. I have had to cut some collars off.
The axles may pull out of the tubes easily, OR they may not.
I made a PULLER out of an old axle that fits over the installed axles flange lugs, and use a 10# barbell weight as a slider.
I've also had to cut axles out.
If NOT, do like Larry said below, remove the bolt and drive the Attex around until the axle brakes lose inside the sprocket tube.
Sometimes the axle has to be cut out and you should be able to find a few threads on what to try next.
If you are pulling the frame, the axles, tubes, sprockets and chains all need to come off before pulling it.
Good luckLast edited by PlumCrazy; 10-05-2013, 10:29 PM.The trouble with retirement is.... I never get a day off !!!!
