T-20 is repaired and re-assembled. Frame moved to garage build bay. 66 deg feels even better than 36
. Trans mounted in frame. Engine on mounts set in place. Driven clutch sat further out on the input shaft when the big brake discs where installed. I opted to put the driven all the way onto the trans which required shifting the engine aprox. 1/2" to the starboard side of the machine. That being completed,things appear to be lined up to my satisfaction. Need to re-rivet my fresh air intake in one place and this should complete the "removal" part of the old braking system. (yeah,imagine that,a lot more to the "removal" process than just removing things.lol!) As soon as I get and post some pics,I will elaborate on the "new" front axle disc system. Need (want) to make some spacers to keep the sprocket tubes held captive between the inner and outer bearings and then it's pretty much a "drop the frame in and put everything else back together" operation. June is rapidly approaching
. Oh,wait,lets tighten the two lug nuts per wheel that I put on hand tight the nite before,yep,that cured it
. Oh,wait,how dead was that battery,pretty darn,eh? Yep,just the stator trying to put a 15 amp charge on the battery through a 10 amp fuse
. Battery placed on charger
