Attex project
I thought it looked good the way it was. The beer errr cargo holder would be a good addition, but mismatched metal on the cover is cool.
I like it! Nice work! I like both sides but I almost like the diamond holed side better then the square holed mesh.
1st try at the engine cover using anything I could find in the shop. I like the way it came out. I will clean it up a little bit and find some matching expanded metal for the top. I'm also going to build a luggage rack for it.
yes. direct from cylinder to oil return galley. The engine would smoke a little when getting on the gas. I pulled the air cleaner and saw the breather blowing oil right in to the carb. Holiding wide open, I did see a puff of smoke from the gasket area, then I saw it leaking oil.
I can't tell from the picture Lance, but was the crankcase getting pressurized from a bad head gasket?
Still plugging away! Had a lot of blow by coming out of the breather. Of course it didn't fix itself. Parts are on order, should still be ready to ride.
Nice job Lance! See ya in 3 weeks at Ash. Yep,little Attex is a blast after lumbering around in an Argo or IV.
Ran the Attex this weekend. No major issues, just some chain and throttle adjustments. My daughter took over and did about 25 laps around the yard. Need to get the rollbar fabbed and install some seat belts. Hopefully done for Ashtabula. The 16 HP Briggs and the red spring really give this machine some low end grunt. I need to tweak the governor some for a little more top end. Amazing how nimble this is compared to my Max IV !
Unbolt both inner and outer bearing flanges. Once they are unbolted, you should have enough room to go at the inner bearing with a cutoff wheel. Cut the inner and outer race on opposite sides of the bearing and it should fall right off. If you can remove the sprocket assembly from the axle, you can attack the outer bearing with the axle out of the machine, if not, you may have to cut the axle to get it out, thus having to make a new one.Originally posted by Eric1971 View PostHello.Can anyone tell me how to cut a axle out?Without damaging the tub? Going to try to drill the allen bolts with left handed drill bit first.But would try cutting it if I thought I wouldn't ruin the tub.Thanks.
Looks very nice Lance.
