Ok, I have a 500 Super Chief. What mix ratio is everyone using on there attex. The manual said 20-1 but is this what most people are running. Ive been told make it 50-1 or 32-1. Just looking to get a better idea from fellow Attex owners.
what fuel mix ratio?
If you're using petroleum based oil, you should stick with around 20:1 but with a good synthetic lube you can go 40:1 or 50:1.Stuck in the seventies- not in the swamp.
Only had it for a couple weeks now. Bought it and doing a fuel tank flush, tune up and an UNI air filter. The tank had dirt in it and the former owner wasn't running a fuel filter. I run RedLine 2 stroke oil in my quads and bikes. I plan on running RedLine in the Attex as well. Anyone use RedLine here? And what mix ratio?
I run Blenzal (like the way it smells) and Redline when I can find it in my dirtbike YZ250 40:1 .
In my Attex 400 I have been mixing 20:1 just to be safe since I am just learning about these machines. Its smokes some but runs great and plugs look fine. If it didnt smoke I would be worried.
I would like to make a Uni filter fit, did you make a flange for it? Mine has the flat 3-bolt Walbro mountST400R ATTEX(Smiley)
500 Super Chief
These fellas should be able to set ya up, may need to call them.Originally posted by Andyman View PostI run Blenzal (like the way it smells) and Redline when I can find it in my dirtbike YZ250 40:1 .
thankyouOriginally posted by Nubs View PostThese fellas should be able to set ya up, may need to call them.
https://eccarburetors.com/webstore/f...-adaptors.html
500 Super Chief
