i'm going to look at an attex this weekend. the guy doesn't know much about them... didn't know the year/model. the engine is good, tires are shot, said there are some cracks around the rear axle. is that anything to worry about, or a common problem? i have a terra tiger, but would really like machine with reverse. everyone talks about the T-20... is the baker hill a bad trans? not even sure what this machine has... just wondering what i need to look out for. thanks in advance guys
anyone know the history on this racer?
The Baker Hill is actually a pretty good transmission. If it is currently running and driving and you plan on just driving it rather than restoring it right now, just check the bearings, chains, and amount of travel in the steering levers. Just about every Attex held up very well over the years, but sometimes there would be a small hairline crack that can easily be welded in the front of the frame near the part that is cut out to clear the front brake discs on 1971+ machines. Other than that, I would say that they are similar to a Max or Hustler and to just look over the basics. Plus you could post some pictures up and we could help you out too."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
mccoy. it's up in winston salem... if i don't get it i'll e-mail you some pics and the contact info.
jeff, thanks for the info... guy has had it for 8 years and never run it. said the tires are shot, engine is a rockwell... has compression and spark but he's never even tried to start it! i wasn't too clear about the cracks... they are in the body, although the frame will need a thorough inspection as well. i think i've read a post on here somewhere about fixing the bodyLast edited by racerone3; 04-11-2008, 07:15 PM.A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
went to look at an attex this morning and it was a racer! i had my son with me and it was raining so i didn't get to do a great inspection. the chains were a bit lose, but still had adjustment. right sides turned great, but the left front seems to be locked up... shouldn't be too bad though.... bearings,or chain. if you attex experts will look over the pics and tell me what you think i would really appreciate itA well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
exactly what i was thinking whipper. sell a few things on ebay this week and it'll be on the trailer home next weekend! i'm also gonna take a look at your videos this evening. where does the brake tie in? could that be the problem with the left front not wanting to turn?A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It's either the brake or bad bearings. Looks like it's been sitting a looong time. It looks like it would be a total disassembly project anyway. The perfect time for an 1.25" axle conversion?Originally posted by racerone3 View Postwhere does the brake tie in? could that be the problem with the left front not wanting to turn?
Whipper
i couldn't really get the brake to move... and i don't know anything about attexs. i assume the brake is the lever to the left of the drivers seat? it is in the back position and i couldn't get it to move forward.
yes it has been sitting for a while... the guy said he bought it 8 years ago and hasn't touched it... didn't know any history. as for the axles... i'll probably get it going this summer and play for a while. once winter comes around and my shop empties out (lawn mower season is in full swing) i'll gut it and start figuring out what direction to go. are the 1.25's hard to make? i plan to make my own wheel adaptors anyway. other than welding them on it's just drilling some holes for sprockets right. i've seen the post about using max bearings and flanges. doesn't look too toughA well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
An original ST/400 racer......WOW, what a find! BUY IT, BUY IT BUY IT ASAP! I can't believe how good of condition it is in too. I can only imagine what stories that machine would tell if it could talk.
Again, that is an amazing find!
As far as the 1.25" axle conversion goes, I would say that it is very easy and straight forward. Whipper's jig for the conversion makes everything a breeze. I just did my green poly body Attex and it was a very easy process. Keep us posted on the build when you get it home."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
jp, i'm on it... i'll be picking it up in the next few weeks.
mike, he bought it at an estate auction... doesn't really know the history. i'm going to look through whippers vids tonight. i'm thinking a yankee racer moved south and couldn't leave it behindA well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
i'm going to make some wheel adaptors and put 5 lugs on this thing. i've seen some that are just flat with holes and some that have a tube running back to the ring on the axle like the old balloon tires did. should i build them with the tubes or not? also, anyone remember where the pattern is posted on here? thanks guysA well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
