Attex Alex help
  • Attex Alex help
    Hi guys this is my first post and first,atv resto. I recently purchased a 295 wild wolf that is a totally basket case, i have started to mock the frame and adjoining parts before sandblasting. I have just noticed that i only have one axle and need to get the other five made. My question is before I rush of to the machine shop and get five copy's made from the one I have are all 6 axles the same dimension with the same drill hole postitions or are they different ? Hope some one can help
    There are a few axles with slightly different bolt hole positions. If you have all your sprockets, you can mock them up in line with the transmission using 1" stock or even wooden dowel rods. Once all your sprockets are aligned you can mark your bolt holes. I believe one middle and one rear axle use a different bolt position, but don't quote me on that.
