Colt engine
  • Colt engine
    Found a powerplant. 340 kawasaki.
    The only problem I see is the clutch is so wide that it will hit the body. What have others done? I see 3 possible options.
    1, cut and make a housing outside the body so the clutch fits.
    2. Put the driven clutch on t-20 backwards? Having a hard time thinking in my head if it will work that way or not??
    3. Probably what I should do but track down another clutch that will work.
    Any Suggestions or tips. I should have got a better pict of the clutch I guess.
    Hard to see but that looks like an 800 series clutch, find a 700 series clutch for it and should be fine. They should be plentiful on the 295's.
      Yea it's probably best route. I'll see what i can find. Thanks Jim!
        Larry, I should have suggested checking the driven first, if it's the 9" 700 series, if it's 11 inch 900 series. Hopefully it's not the 10 because that is the 800 series.
          The drive clutch is off an Artic Cat Jag. My issue is the actual width and not diameter. I think I just need a new drive clutch. I attached a picture showing my issue. But when the belt is lined up there is so much overhang off the clutch it will hit the body where my finger is.
            Understand the issue, diameter reference was for matching the drive with the driven.
