I bought a 1970 300st with a broken axle.I replaced that one.Than I noticed the one in front of that is bent.Can I run it like that?Will I ruin it?Does anyone have one they would sell? THANKS.
Bent axle
If the axle is bent so much that it causes the tire to rub on the body, stop driving it immediatlely. If it's only a minor bend, it'll be OK to drive for a short while at lower speeds. Like Dozerlarry said, remove the axle and put it in a hydraulic press to straighten it out.Originally posted by Eric1971 View PostCan anyone else please answer weather I can run it like that for a little while...Thanks!"Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
