rubber mounts
  • rubber mounts
    i just started on the motor and trany for the racer and noticed that almost all of the rubber mounts between the motor mount and trany mount are torn. anyone know where i can find some, or a sutable replacement?
    You can use the rubber motor mounts that Recreatives uses on the Maxes with the Briggs Vanguard engines.
      Also, Grainger Supply sells them. They're under the "vibration isolator" category. Fairly cheap, too.
      ~m
        You might also try McMaster-Carr, same catagory.
        Next day delivery.
        Bruce
          These?
          Are these the mounts you're looking for? How many do you need?
          Don
            exactly what i need Don. i think it takes 4 so i need six. how much??? you wouldn't happen to have any 4 lug 8 x10 wheels would you?
              Is that stud solid through the rubber or is it 2 studs connected in the rubber? Just curious.
                I'd have to look for the rims, Racer. I may have a couple.
                Larry; the mounts are two studs bonded to the insulator.
                  thanks don. if you have any of the mounts, and or rims, i'd be very interested. maybe i can swing by next weekend and pick them up!
