Hey yall. I figure i would put together a tutorial on how to clean up abs bodies and give some detail on abs goo repairs for cracks and holes...
Here are some pictures of the first round of cleaning. More to come.
These pictures are after using a DA sander from Harbor freight as a wet sander
started with 120 and then 220. Used red sanding pads from Home Depot.
Then I took Acetone on a white sock or white undershirt and soaked the shirt and did small areas, one at a time. When the cloth starts to stick resoak in acetone and keep going. I will post some pictures of the material and technique soon.
started with 120 and then 220. Used red sanding pads from Home Depot. Then I took Acetone on a white sock or white undershirt and soaked the shirt and did small areas, one at a time. When the cloth starts to stick resoak in acetone and keep going. I will post some pictures of the material and technique soon.
