New alternator. Made from a GM water pump pulley, delco 100amp alternator and a Internation Harvester Cub Cadet generator pulley. I welded the water pump pulley on the backside of the clutch after cutting out the middle. I measured it out, tacked it on. Measured and spun it. Turned out to be 100% true. Turned out great.
100 amp alternator
Nice job, Larry- you're pretty handy. Do you run a lot of electric accessories on your machine?Stuck in the seventies- not in the swamp.
Nice job
Good looking work. Trolling Motor plus a killer sound system
You've got the juice!!!!
Just kidding: It is nice when things go right. Job well done.Life should not be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways , cigar in one hand, whiskey in the other, body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!!!"
Thanks guys,
I have felt no power differance but I havent really worked the alternator hard. I dont think it would be much of a factor. It has more power then is really needed most of the time. For my needs anyways. I mean I have towed logs, pulled stuck atv's, climbed hills... and never needed more power, just traction.
lol, I would trade music for beer but I am unable to go.Originally posted by whipper-ag View PostLarry, thats not a bad idea. I see a big Boom Box in your future.
Come to the Ledges, we'll hook up to you for our music.
Whipper
As for the bogging it down I left the switch on and killed the battery. I started it with the rope and I didnt notice anything like it was bogging down. It even idled fine. I guess I will try jump starting something and see if I hear a differance like in a truck. I cant think of anything else with a severe draw.
Great writeup on the swap! You were curious about big draw items. The winch if you have one! The 3000lb winch on mine is rated to pull direct 220a under load! There's a correct way to figure out how to winch, and how to charge!
The majority of winch MFG's tell you to not winch more than 30sec, and cool down for 2-3min. The theory of operation is if you draw 250a for 30 sec. andhave a 50a alternator, it will take 1min to recharge the 50a into the battery, so that's 5min to recharge 250a. Sounds insane,and no I don't listen to the theory, but I can tell ya it is possible to overheat the winch, and fry the motor, and is also possible to over workthe alternator trying to recharge a depleted battery from winching!Jeff
02 Argo Bigfoot
Hey thanks Greasemonkey.Originally posted by GREASEMONKEY View PostGreat writeup on the swap! You were curious about big draw items. The winch if you have one!
I dont have a winch. But I updated in comments of the photo and never updated here so I will say I have had the battery completely dead. Pulled rope to start. With lights on and charging completely dead lawmower style batteriy I didnt notice any power differance on the engine. This has me wondering because I was told someone else did same thing and it bogged it down running big offroad lights. The only thing I can think of is the pulley ratio may be his factor. Mine is roughly spinning the alternator 4:1.
alternator
Hi Larry. would you be willing to duplicate your handiwork if I sent you the clutch and get the pully. I am running my superchief off aMazda Miata battery. I have big off road lights on my rollbar that I have yet to hook up because I dont think the stock alternator on the G50B has enough juice to keep up with the draw from the lights. Your setup would solve my problem. I just dont have any welding skills. Iwould be more than happy to pay for the service. Let me know. Thanks
-PatFamous last words: I swear honey... I am just going to change the tranny fluid. I won't tear this one apart...
Larry,
Sweet job on the alt. rigging!have you thought about rigging up an air compressor for on trail flats and such.Also with that kind of power you could even run one of the welders that the rock crawlers use for on trail repairs
WOW! Then with the air system you could throw on a couple impact wrenches and some sockets and be a rolling amphib repair station! You could be really really popular on long treks through tuff country!
WOW!!! Talk about possibilities!
