OK I'm running out of ideas here. I had the right front chain off the Attex to replace the bent axle with a new one from Whipper and now I can't get the chain back on. It's about 1//8 inch short, even with vice grips squeezing as hard as I can holding the ends together and rotating the front tire back to take up any slack. The chain is TIGHT!
I cleaned both sprockets and the chain in case there was some dirt and grease taking up space, and I turned the chain around to see if it seated better one way or the other, but no go. I'm about to try loosening the bolts on the front and middle outside bearing flanges and slacking the chain from the T-20 to the middle axle to see if that might give me enough slack to get the master link in. I even tried adding a link but that's too loose.
One step forward one step back and getting nowhere
