steer stick size?
  • steer stick size?
    ok fellas I need to make 2 new steer sticks for my attex and not sure where to find tubing that's 7/8 od. any info on this would be greatly appreciated!!! Thanks
    3/4 black Iron water pipe from a big box home improvement store would be real close. It is heavy wall for that application, but easy to bend if needed. you could also order stainless tubing from http://www.mcmaster.com/#standard-st...ubing/=12grfql or mild steel http://www.mcmaster.com/#steel-hollow-rods/=12grf4y
      Electrical conduit from a biig box store would be lighter, cheaper and will not rust.
        Forget light and cheap Dave. Go with the 3/4" BIP if you can't find true 7/8" tubing (maybe up in Kankakee?). The foot brake system in Attex machines doesn't have a hell of a lot of notoriety for its true stopping ability so 90% of your brakes are going to be in the T20. You don't want a lateral turning to mush in a hard turn.
          Lol BIP is black pipe?? I have never even tried the E brakes on these machines!!! I always rely on the O **** moment and pull back hard on those sticks!! Thanks for the help!
            Originally posted by racerone3 View Post
            3/4 black Iron water pipe from a big box home improvement store would be real close. It is heavy wall for that application, but easy to bend if needed. you could also order stainless tubing from McMaster-Carr or mild steel McMaster-Carr
            Thanks!! Think I'm gonna go with stainless!! I don't like a sloppy stick!!!��
              I have a set of attex sticks rods and the bottom mounts from thunder chief. Pay freight and they are yours.
                Can you get a quote to 60927 on that shipping please??
                  Will do
                    Will do
                    Thank you!!
                      I can get them in flatrate game box. $20 covered me. Pm full address or text me 907-388-8582
