What attex?
I'm no expert and still learning, what I see is a green poly lower, poly top, seat support, no disc mounts for the trans and what's left of the newer stripe. I'd assume the JLO was transplanted or the body replaced, check the frame for the serial number on right rear.sigpic
That's a Superchief with a green lower/yellow upper, both HDPE (poly) and it has the incorrect engine, a JLO 400cc (from an Attex 400 Chief most likely), but still a very fun machine. For $100 you got an AMAZING deal! Congrats!"Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
Has black poly bottom this is my 4th one I've owned I had one I denticle to this with a 500cc Suzuki 2 stroke and I had a action age scrambler hated the scrambler the hydrolics suck attex is the best old machine I'm pretty sure my current one is all original I believed this motor to be the 399? And I figured it was more than likely a chief all I had to do to this is tires and clean the points and a new fuel pump and new fuel line for good measure
Wayne, if you're simply looking to add an electric start to your existing JLO, I'd post a wanted ad here on the Site looking for parts. On the 4-bolt head JLOs, you'll need the starter, the starter brackets, and the starter ring which presses onto the PTO side of the crankshaft. The electric-start engines required a different crank seal on that end versus the pull-start only engines, but it's very easily sourced and replaced (and always a good idea) when doing the swap. You'll need to get a generic 12V starter solenoid and the rest of the electronics (momentary key switch, battery, cables) as well.
I don't currently have all the parts, but asking here in the wanted section might be more productive (and cheaper) than eBay. Good luck...Last edited by hydromike; 06-26-2017, 02:46 PM.sigpic
Thanks hydromike for that info I'm a mechanic and gearhead so I have knowledge of putting it together just wasn't sure what I needed very helpful. I owned a attex supercheif before and I wanted to the twin engine swap but money was a issue I sold it for 700 and I been looking and heart broken till I found this one on Facebook complete and running! For 100 dollars wedge
