Engine swap
  • #16
    So, do the sled engines turn the correct way?
    Like I said I got 2 engines with it, just kinda need
    To understand how the primary clutch will work with the
    7000 tranny.
    Thanks
    Don
    • #17
      7000 tranny.
      Thanks
      Don
      The engines should work no problem, the convertor will probably need to be wider inside using spacers, we hope. Rickga is currently working through this with a small 4 stroke conversion, the belt width is the main issue.
      • #18
        I have a belt, not sure if it came with sled engine or not.
        It fits the engine but kinda fits in the driven clutch. Kinda trying to eliminate the issue before I have an
        Issue I guess.
        Thanks
        Don
        • #19
          I guess after getting it home and looking at it someone stuck rubber hose in the spring
          Not sure why? Maybe so it would engage sooner?
          Don
