I’m not sure of year or model any ideas?
A few pics of my attex
Don, though we all know you're the Guru I'm gonna jump in here. Unless the trans has been changed as far as I know the 340R and the early (pre t20) 400R came with 6000's.
But the main reason I'm in is, what is the frame difference between the 297 and the 300?
I was under the impression the only change was the axles, bearing hubs and sprockets and of course the 5000 to 7000. Is there extra supports in the frame?sigpic
Probably a 7000 series: that's the better of the two reversing B/H transmissions.
Jim, I'm going from memory so accuracy may be off a little! The 297 models I've had were stingy on frame bracing, more similar to a 208TT frame than an ST300D, and the ST400R models I've had were about half-and-half 6000 and 7000 transmissions, so I didn't take the trans model into consideration. I don't remember ever owning a 340R, but I assumed they were the same deal.Stuck in the seventies- not in the swamp.
Thanks Don, a
A little knowledge never hurts, until you know too much.
