Need help on CVT shimming.
  • Need help on CVT shimming.
    I recently done a swap from my baker hill 6000 to the 7000. The 6000 moved faster than the 7000. Noticed that the same belt doesn't get as deep on the 7000 secondary.
    Can I swap my secondary?
    or
    Is there a way to shim the 7000 secondary?
    Thank you
    if the belt size is the same and the sheave width and diameter s the same it may be the spring tension on the secondary or flyweights on the primary that need correction. probably easiest to change the flyweights on the primary assuming its a 780
    Acta non verba
      would changing the flyweights make the belt clamp the belt higher on the pulley?
        Please show a picture of both convertors preferably with the belt on and off convertors, static.
          depends if the belt is the correct width.
          Acta non verba
