I can't seem to find this information, what's the correct CVT belt for my baker hill 5000? I know it's about an inch or 15/16" wide and somewhere around 45" long, but I can't find one anywhere. I've converted to a 4 stroke, but the original engine was a Rockwell 297. I may fix it and re-install it, but the original belt should work with my current installation because I have the clutch in the same position.
Baker hill CVT belt
The original replacement may have been a gts607 but after much searching and figuring we decided to go with readily available comet belt. It crossed to a salisbury belt that may have fit the attex and the wedge.
Too much research to go through again. I think we figured it on 12.5" spacing incase we changed clutches to a common 780 set. The machining on the driven makes it unfeasible for now. The speed sensitive clutch i believe has a larger diameter than the 780. The machine is in ga and i never got to work on, its rickga's.sigpic
Yea, it's annoyingly difficult to find CVT belts by size. There are some charts, but they don't include everything available. Right now I have some really old belt I had sitting around my shop that's 1-1/8" wide, I had to shim the driven clutch on the baker hill 5000 for it to fit. Kind of a weird operation to shim those, but it works.
What do you mean, changing clutches to a 780 set? Are there different driven clutches available for the baker hill? I figured it's such a weird setup nothing else would fit. I've rebuilt the whole transmission down to each bearing and seal so I know what a miserable pain it is to remove the clutch...
If you look on the Ultimax website and click on the belt name that you want it will give you a dimensions chart. I ordered a couple belts now by size. I’ve had great luck with the Ultimax Max belt.What it lacks in ground clearance it makes up for with traction.
The width of the 300668 belt is pretty good. An inch wide would make me happier, but 0.9" is decent. The length, however, is way off. As I suspected it's a good deal too long. I'm having a difficult time finding anything the right width that meets the length I want... Ideally I'd have about 44" long and between 15/16" and maybe up to 1-1/8" wide.
The primary clutch has a second groove for the width setting which I'm pretty sure is for running a wider belt. Since I have a couple clutches I merged into one good one modified for 4-stroke I might go see if I can just run a 1-3/16" belt. Those can be had in about any length imaginable.I'm fairly certain I can shim the baker hill secondary far enough to run that wide.
Originally posted by tbone9 View PostIf you look on the Ultimax website and click on the belt name that you want it will give you a dimensions chart. I ordered a couple belts now by size. I’ve had great luck with the Ultimax Max belt.Pull up the comet belt chart, golf carts use mainly 1" (there abouts) belts. There is a lot to go through to find your needs.Originally posted by chrisgt View PostThe width of the 300668 belt is pretty good. An inch wide would make me happier, but 0.9" is decent. The length, however, is way off. As I suspected it's a good deal too long. I'm having a difficult time finding anything the right width that meets the length I want... Ideally I'd have about 44" long and between 15/16" and maybe up to 1-1/8" wide.
The primary clutch has a second groove for the width setting which I'm pretty sure is for running a wider belt. Since I have a couple clutches I merged into one good one modified for 4-stroke I might go see if I can just run a 1-3/16" belt. Those can be had in about any length imaginable.I'm fairly certain I can shim the baker hill secondary far enough to run that wide.sigpic
I am using the A/I products A-300668 belt. I have a 7000 BH and i tore mine apart as well. We (Jim and I) explored many options and ended up doing what Toys4me did which is place the motor on struts that allow you to adjust the motor to fit the belt. The belt fits and it allows for adjustment as well. I have a Comet 780 drive clutch set at 1". I tore apart the trans after realizing that the driven on the BH wasn't opening like it should. Now all is well. Hope this helpsOriginally posted by ARGOJIM View PostThe original replacement may have been a gts607 but after much searching and figuring we decided to go with readily available comet belt. It crossed to a salisbury belt that may have fit the attex and the wedge.
How exactly did you put the motor on struts? And was it the stock Rockwell 300cc?
I have the 4-stroke on slotted bolt holes, just can't adjust it back nearly far enough to use that belt. Annoyingly it seems that width belt is either 45.98" or under 40" which are both outside my adjustment range... The belt I have now was just sitting around my shop and measures about 1-1/8" wide by about 44.5" long. I think it was originally a 1-3/16" belt that's just really worn. The engine barely fits, I'd have to do some serious modifications to my current crossmember to move it back another inch to clear the 300668 belt, I may have to do that, though... I guess I could also find an overbore piston for the rockwell and rebuild it...
When I got my machine it had been sitting full of leaves and water for 30 years so I had to take the trans apart and replace every bearing and seal along with making the secondary clutch work again.
His was already cut so we had options.Originally posted by chrisgt View PostHow exactly did you put the motor on struts? And was it the stock Rockwell 300cc?
Try these as he may go here in the future.
Comet 204331, 213295, or what you may want 300632.
I think rick was concerned with clearance against trans before final install, we also had extra steel in frame added by someone to deal with.sigpic
Yeah, that 1" tube was already cut. I have about 6" left on each side. I mounted a 1/4" plate on top of the rails and then attached the struts to it and then mounted motor on struts. I have a 13hp predator in it and its sitting up about 1 1/2"- 2" higher than yours it looks. No engine cover. i will try to get pick posted tomorrow to give you an idea. There isn't much room back there as you have found out lol Because of the lower tub flaring outward on the rear you gain a little clearance as you raise the motor
I had to make that custom heat shield for the cylinder out of aluminum flashing because the stock one hit. As it sits now I have less than 1/4" to the metal support between the sides. There's actually a few inches clearance between the engine at the back of the tub, the issue is the bottom of the engine hits the back of my motor mount. I kept the stock motor mounting tab on the back of the frame which limited my adjustment range. I initially restored the machine with the Rockwell engine which turned out to not work for several reasons, I had the gx390 already sitting around my shop, the choice was clear. The engine was actually from a generator so it had a j609b taper shaft, however there's just over an inch of shaft that had a 30mm OD coming out of the engine. I turned that down to a 30mm clutch taper and used the stock two stroke clutch, obviously modified for 4-stroke RPM range.
I could cut the stock rear mounting tab off the frame, but then I'd have to weld something else on without melting a hole in the ABS...
Also, how in the world did you find those CVT belt part numbers? I've had little success searching by size, but you seem to have nailed it with one of those. I'll have to do some careful measuring, but the 300632 belt might just work. 45.2" isn't much shorter than 45.98" but it's ~1/16 wider so it'll sit higher in the secondary.
Chris, i didn't get pic yet but Jim and I were talking, and i actually cut out the mid section of my upper to make room for valve cover area and exhaust. Think Jim found another belt that is 44"+ that will work for you. Looks like your machine is clean and uncut so let's keep it that way lol
