Wild wolf 295
So it dies when it gets warm. No spark at spark plug. What kind of signal or voltage should I have going to the external coil? During crank.
When I look at it I realize it cant be that ground cable. The starter wouldn't have worked without it.
It still died after 15 minutes or so. Started back up after 20 or so. Had to pull the neg wire on the coil to kill it when i got it in my shop. There is a cable from the cradle to the chassis and one from the chassis to the battery. I guess Ill check the one from cradle to chassis next.
Am I to guess it out rode your last trip? We may have gotten somewhere, if your engine is rubber mounted (anywhere including the cradle) there needs to be a ground cable/strap from engine to frame or engine to battery and battery to frame (switch).
Going back to switch searching for ground.
So here is a question for ya. I replaced the wire from g on ignition switch to chassis ground. went to test drive it and it wont shut the engine off by the key. Does the ground wire go to other places besides chassis ground? Did my wire pass something?Last edited by 507rzr; 02-15-2020, 07:40 PM.
You may be on to something there, I think I might replace the ground wire from battery to ground post on switch also. Be sure kill wire goes to M post and ground goes to ground post, if they are reversed goofy stuff happens. If there is no ground the switch may be seeking a ground.
Well tonight is slightly different. I found what I am gonna call a "weak" spot in the ground wire that goes from neg to ground on the external coil. I replaced it with a wire that has alligator clips on both ends just to test. The engine idled for probably 30 minutes before I did anything. Decide to test drive it. So, I went out and back, out and back, you get the picture. Not real trusting cause i have pushed this thing in my barn too many times. finally it dies. No spark again. test light on wire from ig switch to internal coil shows a pulse during crank. still a pulse to external coil also. Sat down to so some reading and studying for 20 minutes or so. Decides to try it and it started right back up. I guess my next try is to "replace" the wire from ignition switch to internal coil and swe what happens.
I haven't read back so I apologize if you did this already but did you try another spark plug? Was is the condition of the wire going from the coil to the spark plug?
This thing just keeps throwing me curve balls. Like I said it runs great for about 10 minutes then loses spark. I have replaced the external coil to no avail. I even put the other coil back on while it was at room temperature and still no spark. I replaced the points condenser. Replaced the internal ignition coil and the same thing happens. What am I missing? This is a simple system. All of the components have been replaced that could make it lose spark. I guess I need to check wiring very close. Maybe even the ignition switch? I did replace the switch long ago with one I got at NAPA. HELP PLEASE!!
So where does a person find part numbers for parts? I see a few available on ebay but without a part number i don have a way to verify that it is the correct one
