I'm having a fuel problem with my newly acquired wild wolf. Has a jlo 295?. My question is, the is the fuel line that is connected to the carb which goes to som sort of block mounted to the frame. Then the line goes to the fuel tank. Also, coming out of the block on the frame is another line that goes nowhere. I dont believe taht this block is a pump or anything because there are no wires going to it. I cant get the motor th run out very well and seems like i cant get the carb adjusted right because of the fuel pickup problem. Any help would be greatly appreciated. Thanks guys.
attex help
the block is probably the pump, the line that goes to nowhere should hook into the engine block. the pump has a diaphram that is actuated off of crank case pressure. not sure where it hooks up on your particular engine, but someone will chime in with that info.A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
There's a nipple on the rear of the 295 below the carburetor that the other line goes to. Congratulations on the new Wild Wolf!Stuck in the seventies- not in the swamp.
