Wanting to replace the Mikuni carb on my WW295. Is there a direct replacement that everyone is using?
295 mikuni replacement
A VM28 or 30 should work fine. If you use a model with the rubber snorkel type mount, it will be less likely to vaporlock in warmer weather.Stuck in the seventies- not in the swamp.
Make sure you change the needle and seat. I think it should be a 1.5. The ones that come in the new carbs are much bigger. If you don't change it you'll have fuel running out of the bowl big time.
https://www.mfgsupply.com/snowmobile...r/07-410j.html"Racing is life. Anything that happens before or after is just waiting."
I know these guys are racing this weekend so I'll jump in here and say your gonna need the rubber flange for the carb to mount to if you dont have that already,I'm not sure what size the bolt pattern is either but ebay or mfg supply will probably have what you need.Originally posted by 507rzr View PostSo no other parts? Just buy a carb?
Good luck with your project
Dave
