Good afternoon fellow 6x6ers. I have a 76 super chief, with a bit of a fuel problem that I am reaching out to the masses to figure out. When I am cold starting the machine, it wont grab sufficient fuel to start. It does not burp or anything it just keeps cranking until the battery dies. When I prime the cylinders (a little gas in each one) it starts and stays running fine indicating that it is pulling fuel. I have the mikuni fuel pump, but I must confess that it is just hanging in the air, and not attached to the frame. It is connected to the block and seems to be getting the requisite crank pressure to pull a feed after the engine is running. Should I mount it, and if so, should it be above the carb or is below it. Thanks.
Attex Fuel Question
Hi PatB, here is an inline primer on ebay cheap. I think Attex and some other manufacturers of AATV's used these. Hopefully this will help you out.
eBay Motors: boat 5/16 inch fuel line primer bulb gas replacement (item 110296716997 end time Dec-04-08 20:02:13 PST)"Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
