ok attex guys did any attexs run the 26in tires or was that limted to the rim . thanks robbie
tires on attex
tires on attex
R.I.P sage rogers 4 11 09 .
you can't fix stuped !!!!! raceone 3 .)Tags: None
23 inch is about as tall as you can go without rubbing the body unless you do some mods, Robby. Thinking of adding an Attex as a second machine?
naaaaaaaaaa to fast for meOriginally posted by Don View Post23 inch is about as tall as you can go without rubbing the body unless you do some mods, Robby. Thinking of adding an Attex as a second machine?
jest learning .got a max II to hop up . thanks don
Last edited by rdr; 12-09-2008, 11:55 PM.1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
