Here are the quick plans. Gonna get the JLO out and beef up the frame a bit. Chains and sproket check and replace then to the adapters (thanks Brian!) to get the balloons of and switch over to some aluminum 4 lugs. Up in the air about tires still. Back inside with a Kawasaki 440. Looks like the Baker Hill is in great shape! Little mod for some safety shields and a Highback seat from Summit as well as a nice cover. Anybody got an extra 5 point harnes? They are pretty expensive too! Front mounted tank looks good. Some filter and line work and see where we stand. Don't know about the roll cage yet but may go to a little differnt design.
It'll go so fast in a straight line, but when it comes to turns you can't push it too hard (since they're so narrow) or you'll roll.....see my avatar. You might want to make some new axles that are a little longer so the machine sits wider and it is more stable. Sounds like a great project!
