Hi all. Just wanted to get some advice from the experts before my wife kills me. I have a Tomahawk 450 that is set up just like it came from the factory. However, I was not able to get a tach on it in time to adjust the governor before problems hit. The OH16O will not start for some reason. Rode it Sat. night and Sunday morning she was sick. Pulled the plug and replaced it, but there seems to be some sort of metal on metal noise when I try to start it. I bought this thing for $2100 a little over a month ago and I am trying to get the most out of it for the money. Rebuilding engines isn't exactly my forte. Should I get the engine rebuilt for me (assuming I can't get it to fire up again), or should I buy a new engine (suggestions welcome). I liked the nostalgia of having a stock drivetrain, but I wouldn't mind getting a little more speed. I posted this here rather than in the engine section because I want the advice of the Attex enthusiasts, and value their advice. Thank you in advance for any response
What would you do???
Hello Drew,
Was it running ok when you shut it down? Is oil level ok?
I would try to locate the noise. The noise may be something simple. Could it be the clutch? If you stick a hose near your ear and hold the other end around maybe you can see if its top end or bottom of motor? If you attempt a rebuild Im sure ifyou have any questions someone can answer. Sorry to hear about that.
Update
So I cleaned the carb. It needed it but did not help. Oil level is still perfect from when I changed it 2 weeks ago. Engine does turn over and the plug smells like gas. If I take it out and turn the clutch by hand you can see the piston moving up and down and it feels like it is compressing. jpswift1, anyone with an amphib is always welcome at my house. However I will be camping Aug 7-9. If you are up during the week, beers on me if you want to help. If its running again by then your still more than welcome to stop by for some driving fun. Finally, Roadtorque, I tried uploading some video of me trying to start the poor little engine, but after a half hour of waiting for it to upload, I decided to just post a link to it. Untitled
Thanks guys.l like to buy stuff and no I don't do payments!
ok Drew, i just watched your video. have you checked to see if it has spark? compression seems ok (as best as i can tell from a video). i couldn't hear the metal on metal that you described... perhaps just the starter gear on the flywheel gear??? if it does have spark, you might have a sheared flywheel key. it would spark but at the wrong time and not ignite the air fuel mix.A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
Thanks for the video. I could not hear any metal on metal. Like others have said check the spark plug for a spark, along with tight, clean connectons on wiring going to the plug. You said the plug was wet when you pulled it so it is getting fuel, now you just need a spark! Keep posting what your doing and we can all work through it.
Hey Drew,Originally posted by amphibious drew View PostAlright I gave her the old hillbilly spark test (screwdriver in the wire) and could not get any spark off of anything I touched while cranking it over.
Well if it was the key, it should still spark, just not at the right time as long as the flywheel is spinning which is is for the starter to spin the motor over. So I would go for maybe a wiring issue. First thing I would do from here is locate the kill switch wire. Usually a black one coming from the coil. If that shorts out on anything it will kill the spark. So disconnect it and try again for spark. Hopefull this is something as simple as a wire gone wrong somewhere.
Is it still making the noise you heard. I dont hear anything. If there was something maybe the coil came loose and hit the flywheel or something.Last edited by LarryW; 07-28-2009, 08:20 PM.
