Andy, I had a long talk with Matt O. last winter about doing what it is you want to do.
He figured anywhere from 60 to 80 thousand dollars to do a production run of close to 100 complete bodies. Making any fewer would not be much cheaper as you have to buy the HDPE by the ton.
He also said that you'd probably get about a dozen bad bodies before you "got it right."
He figured a mold maker could make new molds for about $15-$20 thousand. The nature of the forming process and the molds are such that they can only be used for a handful of production runs before they begin to fall apart.
He also told me that HDPE shrinks upon cooling. If you use an existing body as a mold, you actually have to cut into quarters so that the mold will be slightly larger (by inches) than the original dimensions.
I'd buy one if you have more luck than I did.
), so do you think it would hold up to all the beating? what about a skid plate made of fiberglass if it is that durable? i'm just brainstorming a bit here lol.
