bought an attex tonight
  • bought an attex tonight
    so i bought a 300 sd tonight problem I am having getting her running is electrical i think. Anyone have a wiring diagram??? or info would b great. It has compression gets spark and i just can't get it to fire up
    motor help
    was it running b 4? bad fuel? u flooded it maybe?
      3 wires come out of the back of the motor and the guy had only 1 hooked up..... he started cutting wires and trying to rig it up. I had to save this thing from the chop shop guy lol
        motor misey
        What color are the wires? if your getting spark, fuel it should run.///
        unless..... see my first reply
          i tried pull starting and it spit gas out the carb and it didn't smell good so I disconnected it and sprayed starting fluid in the carb but still nothing. The wires are black all 3 coming out the back. Spark is good its puzzling the coil has been switched to a car coil if that matters. It did run He said Just not now I saw it run last week. The guy said he thinks the coil was bad but it sparks
            motor misery
            try a new spark plug yet? what motor is in it?
              no i didn't
              I am dying to ride it too lol
              oh 1 of the 3 wires coming out the back is wired to the coil but doesn't look right
                I am about to get ready and go mess with it somemore I hope I can get it running. Ithas great compression spark and starting fluid not sure why it didn't start unless I flooded it out before I tried to take the fuel lines off
