Must be your talking about the hubs? Assuming because you said you just bought them. If I remember you had the square style and upgraded by buying junk off A man? The square end style ones don't come off. If its the wheel hub on a non square ended axle I would take a cut off wheel and cut a slit in it parallel with the axle. I have done this and was still able to use the hubs. I almost wonder if that is better with a slit because the bolt will pinch the hub on tightly to the axle.
1st generation axle bearings
i did have the square style but then upgrade/traded/paid lots of money for junk for 1 inch axles and hubs that had bad bearings haha i broke the cast aluminum piece that mounts to the body, its the smaller of the two styles in the pictures you posted larry, but that i think is my last resort that i think im going to take haha but that still leaves me one hub short. anyone have one?
