Hello Folks; Would anyone know what pop rivets to use on a poly skid plate? I know I want sealed rivets, but all the ones I've found seem to have the standard size heads, I thought the bigger ones would be better! The ones I found doesn't say if they are any GOOD on plastic because I know some can pull through softer mat'l. Thanks again Brian!
Hey Folks; Been trying to get a poly skid plate on my st300d for a couple of months now. Something else always took priority! So finally got to get started, wouldn't you know it 1/2 an hr. into it things are starting to bend and form my heat gun said NO more. So I called my friend to see if he had one I could borrow, he brought it over, and needless to say we killed that one in about an hr. So I went the machine shop I work at part time to see if my friend/boss had a heat gun, so he handed me this heat gun that looked like it could melt an iceberg. 220 volt / 750 degree comm. unit now that worked after I made a special extension cord, almost done now! Hopefully before the snow flies! Check in w/ pics soon! Have a Good one! Brian
