The fellow I got the Attex from said he had a lifetime of experience in the plastics/composites industry. He said that poly and abs shrink at much different rates. If similar tooling were used there would be dimentional differences between the finished products.He still has (which I'm seriuosly thinking about just buying) a complete frame,a set of sprocket tubes and an upper and lower tub both of abs. The lower is pretty much destroyed but the upper is in decent shape. He said he originaly wanted to use the abs upper with the poly lower(that i now have) but discovered they did not match.
I'll take and post more pics real soon. The floor pan I have seems like a "harder" matl also(believe its abs),has some metal reinforcments added to it,not sure if oem or after thought and is repaired in one area with fiberglass. Thanks for the frame ID info, I will check it out and have a look at my unit tonite. There are a few nice scratches in the lower and the color looks consistant (no gray beneeth). I'll try to get good pic and post it. Whats the timeline on the poly Attexs, aprox what year abs to poly? Where there ever any fiberglass Attexs? Thank again for all the knowledge,keep it comming,I find the history on these things fastinating
Joe.
Joe.
. I have the remaining #'s written down at home,will post them later. Thought I saw somewhere (this thread?) where the remaining numbers less the last two were elaborated on by I think Larry W but can't seem to locate that now. Joe
