Larry, thanks
I have the more common non-rounded style bearings. I almost got 1 axle apart tonight, i was able to get the most outer part of the axle off (the part with the wheel drive flange on the end). then was able to press the bearing out of the aluminum housing, after removing the snap ring. So know I have a solid axle thas has the bearing still on and some sort of collar that the seal seals against. Does the collar come off also ? Looks like the solid axle might be bent ? Can the seal collar be purchased ?
The collar comes off. Make sure you press the bearing towards the collar because the axle is 25.4mm one side and 25mm on the other side.
For the seals, you can take the old seals in to napa and they can measure them up and order replacements. It may not hurt to bring the bearing and the axle in to so they could measure that. If your lucky they may be able to just go buy the numbers on the seal if there is any. I took one in once and I think it was near 10 bucks a piece.
For the hubs you can make them. Member Birddog1148 made some and showed what he did. His posting is here, post #87-88 shows the details if you dont want to read through the whole thing.
