Please help me Identify the model of this attex
Is the hole on the back upper body an exhaust outlet? If so then its a 208tt. Or does the exhaust exit just above the left rear tire? If it does it is probably a st300. Do you have the original engine? That would help. Also usually you can see what model it is by looking closely at the side on the front upper body. There was stickers there saying what it was. If the sticker is gone it still reacted with the plastic so you can still read them. Depends on how thick the paint is I guess. Even sanding dont get it out completely. Unless the sticker was removed at a young age.
The hole is in the middle upper body.I got this attex with my scrambler both in total disrepair no engines etc.this attex drivetrain is actually in much better shape than the scrambler was.I decided to attack the hardert of the 2 first.There is so much paint-bondo-goop which might be fiberglass resin splattered all over the body but I am going to check the locations you identified.I am looking forward to drivinbg a 2 stick machine.
Looks like a 208tt. The trans set up looks just like my 208tt. Also my St300 has a fuel tank under the dash. The 208tt had a fuel tank mounted up in the back. I'm not sure if they are all alike, but my 208tt did not have the hole for the fuel tank cut out in the front.Attex Supechief-Attex ST/295-Attex ST/300-Attex 208tt-Roughrider-1969 Argo 6x6
