which body do I have? HDPE or ABS?
  • which body do I have? HDPE or ABS?
    I have what seems to be an early model attex 208tt.I read somewhere what the early body material was but once again I cant find it.Could someone let me know what the attex bodies are made of-HDPE or ABS?One thing nice about the scrambler is fiberglass is so nice to work with-someone tried fiberglass patching areas of the attex and it is falling apart so I would like to try to do a decent repair.
    I believe you have an abs body there. Someone pulled the old fiberglass and tin trick on the racer I'm building now. I'm attempting to make the abs goo right now.
      Thanks for the much needed info.
        no problem. I'd use acetone to double check. If it brings out the color then you know for sure. Sometimes people piece machines together so you never know.
          cool.I will try it.Let me know how your goop works.
            Amphibi drew is right, yours is abs.
