Going to look at this machine tomorrow, seller want's 1350.00 o.b.o, all original except 6 new 5 stud tires, rims, adapters, it is a 4 chain model and he say's it run's and drive's perfect, what do you guy's think it's worth, seller said tire's and rim's cost him 850.00 a couple of year's ago and he hasn't used it. Thank's. Shaneshane attex (Small).jpg
1974 attex 252 crazy colt
If the tires are indeed that nice and the machine is perfect its probably not a terrible price. Make sure there is no cracks and tip it up on the side or something to make sure you can see the bottom good. When its up double check all the axle bearings and turn the tires to see how much slope is in them. If it seems like a lot see if its a chain loose or if the sprocket or wheel hubs are wallowed out. Check the transmission and make sure there is no gear oil in that instead of ATF. Take it for a spin and make sure both side brake and engage the same. If one dont match the other it could be a sign of transmission needing bands. Which is pricey. Make sure it shifts forward and backwards nice and easy. That is about all I can think of to check assuming it runs good. Good luck, keep us informed.
