I'm slowly starting to repair my 73 Attex Chief. The first abs repair I'm tackling is the floor pan. The black ABS cockpit floor has several cracks in the bottom -  mostly in the rear corners and and the bottom edge and one from the edge to one of the holes the control levers come through. This seems to be where you would put your weight when getting in and out of the machine. A previous owner tried to repair these with fiberglass, but just made a mess of it. I've scrapped most of the resin and glass off and have begun to weld the cracks back together.
I'm using a soldering iron with a 1/4" wide tip and black abs "welding rods". I ordered a sheet of 1/8" black abs sheet from McMaster Carr and cut it into thin strips on my band saw. I open up a nice "v" trough along the crack from the bottom side, and then I melt in the abs welding rod to fill up the v completely. I then melt in more abs from the top side. This seems to be working pretty good, the areas that I've filled in seem fairly stiff and solid now.
What I'm wondering is what can I do to reinforce the floor pan once it's back in the machine so they just don't crack again when I start to stand in it? It seems like there is no support under the floor when it is in place. It's pretty hard to tell how much clearance is needed, and if I could put a sheet of plywood or some other stiff sheet under the abs floor that would rest on the frame. I would like this machine to look pretty stock when I'm done, so I don't want to build a brand new floor like some of the racers have, just something to take the weight of someone getting in/out. Anyone have any suggestions on how to approach this? The stock floor pan seems pretty weak given the number of cracks mine has, so I'm guessing others have had to deal with this.
Thanks
Tom
Thanks
Tom
. Great idea!
   I failed to mention in my earlier post that all cracks were welded before they got the goo/ glass
