My Attex Chief has a bent right front axle that I need to replace. I was able to loosen the inner and outer bearing collars no prob, but when it came to removing the sprocket bolt, it was stuck in the axle big time. I I guess this really is a "body bound bolt". Before I resort to cutting and drilling the bolt out, anyone have any suggestions on how to get this out?
  I don't know what your tooth count is on the sprocket (probably 20 or 22), but obviously you have to stick with that number of teeth.  You can cut the old sprocket off the tube with a hacksaw; just cut through the weld on each side of the sprocket.  It works pretty well.  You should be able to drive the old tube out through the sprocket at that point. Take the old sprocket tube down to a metal supply shop and get a piece of 1" diameter DOM tubing (NOT pipe, it'll have a weld seam, and the axle won't slide in there...) and have them get you the same wall thickness.  If they can provide you with the same wall thickness, your sprocket should slide right onto the new tube.  Make sure to test fit the tube on the axle, and the sprocket on the tube to make sure everything is lined up before you drill the new axle bolt hole and get the sprocket welded on the tube...
