I wanted to share the progress I'm making on fixing up my Attex 400 Chief. It had a pretty nasty repair to a crack that started at the muffler hole and went down the side and under the bottom almost to the middle. The repair used just about every material imaginable. As I tore it off it was like an archeological dig. The first layer was fiberglass/resin. next was a piece of thin sheet metal riveted on. Under the metal was something that looked like bondo, and finally there was silicone caulk filling the actual crack. It actually seemed to be water tight, but it was really nasty looking and was starting to peel/crack off. I have repaired this by cleaning off all these layers of crud down to clean abs, and then I welded the crack together. After that I covered the welded seam with some yellow abs goo I made from a mix of yellow and orange legos. After the goo was fully cured I sanded the seam down to get a smoot surface, and covered the entire crack area with fiberglass cloth soaked with a thin mix of the lego based abs goo. Next I will add a layer of the glass/abs on the inside to fully reinforce the crack.
Here is my Lego ABS Goo:
