it runs
I got the 440 Chief running, but.......
The correct way to fill the trans is to Remove top plug and bottom plug, its on back/rear of trans, down low..its a bugger to get to also...once bottom plug is removed, pour fluid into top plug untill it runs out of bottom plug, then your done..install plugs and enjoy! lol
as for fluid, everyone on here runs something different i think..lol i bought the best most expensive fluid i could fine. (it should hold 1 qt total. thats from being totally empty, to completely full. The guys boast about the "GM Sure Trak" fluid i think its called. Might be Ultra Trak also..lol im sorry, bad mind today. anyhow, do a search on here and you'll find what kinda im talking about.
Something else to look at is, How far out do the plungers come? when you pull the stick or push the stick, how far out do the little plungers on the tranny come out? It may have band issues?I have officially caught the 6-wheel-sickness!!
Originally posted by Just Playin View PostI took the fill plug out and there does not appear to be fluid in there, what is the procedure for and drain and fill and with what fluid
Add an ounce or so of limited slip differential additive (available at just about any auto supply store) to reduce/eliminate band chatter, should it develop. Right now, it seems that your transmission is a bit twitchy, so after adding fluid let us know if it acts any differently for you....sigpic
