My 400 Chief had a run in with a tree and now my right front corner is damaged at the upper/lower body seam. Both top and bottom flanges are broken away from the body right at the corner for 4-5 inches. Any suggestions how to make a strong repair that also looks ok? I have done a lot of ABS repairs (abs welding and abs goo with fiberglass) on this machine already, but all on the lower hull, mostly not visible and easy butt joint cracks. This one will be visible (if i used abs goo reinforced with glass cloth) and is right at the angle between the flange and the body so not much room to work.
Thanks for any tips.
Tom
Tom
