Just finished assembling a 1974 295 wild wolf. Two problems i could use help with. Pulls left when driving straight.Adjusted t20 plungers and checked all linkages and tire pressures.Possible band problem? Second problem is with the belt and clutches.T20 and secondary clutch was replaced by last owner. Secondary clutch looks like it takes a 1" belt but primary clutch could take a 1 1/8 or 1 1/4 belt. Any one know propper belt and secondary pully size for the Wild Wolf?
wild wolf drive issues
Hey Jeff b,
Are your bearings good? Also, you can't go by tire pressure. You need to measure circumference. The same tires with the same pressure will read different circumferences. Grab a rope,belt what ever and use that to measure and adjust the air accordingly to make them match. I dont have my machine here to measure the secondary for you but I think that sounds about right. Hopefully someone else can chime in for your clutch issue.
