On a Superchief with stock exhaust in stock location what is the max size tire/rim combo that can be used?
Maximum Tire Size
Are you possibly adding a Superchief to your fleet?!Originally posted by North Country Tough View PostOn a Superchief with stock exhaust in stock location what is the max size tire/rim combo that can be used?"Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
The deal has been made to put one in our camp, unfortunately time pressure on the side of both party's will put the actual pickup time till later this spring as well the present owner is taking the time to go thru the unit before pickup,very nice of him,ownership this year is a certainty,so Iam starting the hunt for tidbits here and there,the machine is as close to spot on as a older unit can be but I want to take it to the next level.I have waited this long,its going to be a great year here thats for sure,and when it gets here I will be posting pic,s like any proud Pa Pa,and be actually legitimate on the Attex forum.NCTLast edited by North Country Tough; 03-19-2012, 06:14 PM.
Those 24's would be pretty close, but with some minor body reshaping by applying a little bit of heat I think you might be able to pull it off. Only one way to find, and that's to give it a shot. I'd like to see how it looks, actually. I have seen 23x10.50x12's on a Superchief and they fit without any modifications, so you never know....."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
Thanks JP, unfortunately wont have the machine home for a while,guess best bet would be hold on to the tires and see,if a no go put them back on the market this summer.But as far as reshaping not sure I want to alter the body Iam looking to make this unit as clean as possible.NCTOriginally posted by jpswift1 View PostThose 24's would be pretty close, but with some minor body reshaping by applying a little bit of heat I think you might be able to pull it off. Only one way to find, and that's to give it a shot. I'd like to see how it looks, actually. I have seen 23x10.50x12's on a Superchief and they fit without any modifications, so you never know.....
