Well I did it now! Along with my two vw baja's, the sand rail, two dirt bikes, and three different 4x4 trucks....... I am now the proud owner of an attex 400 chief! It's all here, mechanically anyway. I need a few parts and pointers to get it up to its potential. First of all is there any way to tighten the chain sections (2) on either side of the trans, to the main drive chains that run parallel to the floor, all of the rest of the chains seem to be in good shape with no chain drag. It seems like I might be able to loosen the motor mounts and pull it up a little, but it does'nt seem to be enough to take out all the slack not to mention that where the steering rods connect to the trans. There is a piece of angle iron that would rub. I thought about replacing the chain, as it may have stretched....... I just figured I would ask first! I did see the manual section and plan on printing one off as soon as I get some more stinkin' ink for my printer...
Also does any one know of a place to get parts? I don't really NEED anything, but wouldn't mind replacing a couple things. I do not have any headlights on it so i would buy some of those right away if they were available, I could also use a couple extra sprockets, mine are all here one of them has a broken tooth, and would just like to have an extra in my tool bag for "JUSTIN"
One last thing, when running lights or a radio or any 12v item, how do i get charge back to the battery? thanks all for your time and info!!!! -jake666
