Hi folks, i just got a wild wolf with a 295 rockwell ss....where is the stock mounting spot for the fuel pump and whatbare the stock carb settings and what is the stock carb..my engine has a mikuni now with a bowl mounted main jet,,,my camel has the same engine with a different carb,
72 wild wolf carb and fuel pump info
The Mikuni is the stock carburetor on the 295 in your Attex. Try (lightly!) bottoming out the idle mixture screw and then backing it out a turn and a quarter for a starting point. The only other adjustment that'll really have a huge effect is the idle setting, which is the upper screw that tightens against the throttle slide. Most Attexes had the stock fuel pump mounted on the upper cross brace right beneath the engine cover hinge, but I can't be positive on the 'Wolf. The cross-brace is a good spot, though....sigpic
Thanks, but I think it's a little more complicated than that....the airscew only hadles very low speed engine jetting..i need the stock pilotjet number, needle jet number, needle number and the main jet number....I finally got it on the trail today, it rips stops on a dime, but is still a little boggy at times. float level is 22-24 mm and it's always best to mount the fuel pump below the carb
