Can anyone give me the part number or size of the inner axle bearing (the one that is mounted to the frame, on an Attex ST/300/D? Thanks for your help!
Attex ST/300/D Inner Axle Bearing Part Number?
Give Buffalo Bearings a call at (716) 874-1720 with the specs that Larry W gave you and they'll take good care of you. Many 6X6World members go through them and they're always very helpful and give you excellent prices on high quality bearings. Good luck with it."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
Will this bearing work? FYH Bearing SBPFL205-16 1" Stamped steel oval two bolt Flanged Mounted Bearings
Nope, you need one that is a press fit into a single piece stamped flange, this is a two piece. All ST model Attexes (and 252 Crazy Colts), 1st and 2nd generation used a one piece stamped flange."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
