Hey I just sanded the white fade out again then used the Acetone on it real light and it made it shine. I did not need to go over it with the 500 grit it was good enough for me. You were exactly right. It also kind looks like it has a glassy hard shell too. Very happy with it so far but I still have some paint to get off in other places. Yes, I should have got some pics before I started but you can still see what it did look. I will get them uploaded soon.
Bed liner product on Attex Body
Update on the paint removal and it turned out really good. I used the yellow legos to repair one crack but i did not like the color difference. Is there a trick to making the colors blend? I would like to purchase some Yellow Attex plastic if someone had some scrap laying around. I have some pictures of the progress but
I forgot how to upload the pictures. I found the instructions to the gallery page using Photo bucket. I uploaded before without using Photo bucket and just cant remember.
Originally posted by kat266 View PostUpdate on the paint removal and it turned out really good. I used the yellow legos to repair one crack but i did not like the color difference. Is there a trick to making the colors blend? I would like to purchase some Yellow Attex plastic if someone had some scrap laying around. I have some pictures of the progress but
I forgot how to upload the pictures. I found the instructions to the gallery page using Photo bucket. I uploaded before without using Photo bucket and just cant remember."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
Removing paint
I forgot take pictures before I started but the whole top was covered with paint.
ATTACH=CONFIG]9284[/ATTACH]paint side.jpgAttached Files
Amazing work! It looks like that Chief has undergone quite the transformation. That looks ten times better in its original bright yellow color than any paint or bedliner. Plus this way, nothing will be chipping or flaking off. Like Drew said, it's a good bit of work, but it's really worth it. Keep it up and thanks for the updates."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
These pictures are better. The paint is actually off the top now and I will get those pics soon. This is the other Chief that my Father helped me put together. Everything was in the green body. He is a retired Machinist and Fabricator and he made the body band for the 3000lb winch. We now want to make a rollbar. Does anyone know the measurements for the factory Chief rollbar and the size pipe used? Once the rollcage is built I will swap everything to the Yellow body. You were all right about not using Rino Liner and to remove the paint. It really looks good and my Father was also surprised how good it turned out.
