is there anywhere to find pdf blueprint spec drawings of the 8x8 frames?
It's basically an ST style, second generation Attex frame just with an extra section of frame rails added to the front.......there isn't anything else really different."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
8x8 frame idea , opinons
I was just thinking even if I find a 8x8 frame up north somewhere the shipping would be more then materials for building one so thinking about building the frame to and all but can't find any PDF blueprints with specs so I started playing with this ya'll tell me if you see anything that is really off.
What I got planed so far is 3" x 1/4" aluminum C channel , aluminum to save weight and rust and channel for extra strength to support a springer setup . the frame measures 36" wide an the front and rear are angled, the bottom measures 92" long and top measures 94" right now (but I may have to lengthen it for A-arms) The drive shafts are a total of 16" long and 1.25" solid with a turned down 1" x2.5" on the inside . I have the drive shafts spaced at 30" on center to allow for 28" tires. The bearings an sprockets are not show but I plan double roller chains and obviously the box in the rear is for a jet drive
IF you click your mouse on picture it should start to play
