Having messed with large construction equipment for over 40 years all I can say is close to 100% of everything I've pulled out has been wheeled equipment. Tracked equipment, almost never. I assume the same principle would apply here. The lower horsepower rating might be a factor on the Max. The only time I've been stuck with my Max (other than high centered) was in sand.
6X6'S In The Sand I don't see any information anywhere Help!
If you plan on climbing loose sand hills often tracks would be better. With tires most any attempt to turn will bury it on hills.sigpic
